Posted (edited) · Printing PEI - aeronautics-compliant material
Hello guys, I was wondering if any of you has ever tried printing PEI aka ULTEM which is a filament compliant with aeronautics standards... As far as I know it's developed by Stratasys and supplied with a diameter of 1.75mm. Is it available as 2.85mm for our UM? Any thoughts about this?
    Posted · Printing PEI - aeronautics-compliant material
    I agree that PEI is an outstanding material but I think there a few limitations to using PEI on at least my Ultimaker 2.
    I print exclusively with 1.75 filament and to do that successfully I needed to make a few modifications to my printer. That said I looked into printing with PEI and found that my Ultimaker 2 printer is not within the specifications required for that material.
    1. Ultimaker 2 extruder temp max is 260C and PEI would expect at least 330C
    2. Ultimaker 2 heated bed max is 100C and PEI wants at least 110
    3. Ultimaker 2 does not have heated enclosure but by adding a door you do get some desirable heat retention.
    Aside from the expense of PEI limitation 1 is most likely the show stopper in my opinion.
