Just tightened the red/yellow wires for the temp sensor and it seems to have gone away- the red screw was a bit loose. I restarted the ultimaker as well.
Yes... you were getting a temperature reading of 386 because of the loose wires, which is beyond the safety limits built into the Marlin firmware, so it shut down the heater. Now that you've tightened things up it should be good to go again.
No problems at all now - it did the trick!
astrodenny 0
I tried to re-prepare the print in Cura, then selected print. It preheated, then I received the MaxTemp error again and it will not let me print.
I receive Machine state:Error: 0: Extruder switched
