Posted (edited) · any advice on this print?
For some reason this print builds up material in this one spot. I’m confused why? Is it too hot and building material? If so why would it only be on this one spot? Also any tips on brims? The one tangent spot is the brim and it seems as if the brim gets cooked on hotter or harder it’s fairly different than the rest of the build. material is abs and it was running with the default abs cura settings except for the layer thickness is .02mm
Edited by boovya
