Formatting capsule parametric file - AutoDesk Fusion 360
  • 1 month later...
Posted · Formatting capsule parametric file - AutoDesk Fusion 360
Hi there, I could do that for you.  If you could let me know what parameters you want to be able to adjust then I could see how much work would be involved.  Just so I fully understand your request, are you looking for a file in Fusion 360 (.f3d) format with a parameter table associated to it that would allow you to change certain feature sizes without having to do any remodelling work?
I notice that this post is over one month old, maybe you already have sorted this, if so no problem.
