http://www.thingiverse.com/thing:40544
Thanks for that recommendation - it looks like what I need!
Oh, btw, I highly recommend getting the v2 extruder clamp upgrade with the spring-loaded pressure plate. It definitely solves a lot of problems, and would probably have helped in this case, by giving some room for the filament to slip back past the drive bolt when running excessively fast, rather than continuing to cram filament into the tube until something had to give.
OK, I will look into that too.
Bowden tube broke away from extruder mech
I have managed to reasseble the extruder and printed off this retention mod. Its seems to work very well! See http://tinyurl.com/m92rojp for some additional images of the reassembled extruder with mod. I have also checked into the extruder upgrade which makes it work well with filament thickness variation and look forward to getting it in future. I bought some cheap reels a while back that never worked very well as they were lumpy and uneven. Maybe with the upgrade I can use them. Thanks again for the pointer Illuminati!
illuminarti 18
Oh, eek. That's not good :-( Sorry that happened.
I haven't had that problem, or really heard much about problems with the Bowden attachment on the cold end of the tube... but evidently it does happen. Have a look on thingiverse for possible fixes. For instance, something like this might help... (once you're able to start printing again... perhaps you could clamp the block in place somehow long enough to print a fix? I'd be wary of glue as it might preclude taking it all apart later for other fixes/upgrades.
