Having messed with them, you may well want to try them all before using them on something big. Many of them have odd behaviors, I found the one that worked for me after trial and error.
1
0scar 4
There are post processing scripts available to pause at height or tweak at Z. The first could easily be used to change filament.
You'll find the scripts under main menu item "Extensions" -> "Post Processing" -> "Modify G-Code" and then add the script of your choice.
Edited by 0scarAdded path where to find the scripts
