Try to be specific with the problems you run into. We don't know what stuff is sticky for you.
First get a single extrusion printer going. Start without machine specific profiles ("has_machine_materials": false, "has_machine_quality": false ). Then add multiple extruders, and finally use "has_variants": true and add variant definitions.
mattgriffin 28
Well, while there isn't a handy api resource page for you to help you understand and interpret the various settings, there ARE a number of great custom profiles and the Ultimaker machine profiles themselves that you can load and inspect to learn how they function. The "house style" for Ultimaker is to use a cascade to stack profiles against each other, so that tweaks for a particular model or configuration are later in the cascade of inheritance than the features that apply to more ranges of models and configurations earlier in the inheritance treee. What this also means for you is that you can setup a simple default profile for your custom machine, and then add other selectable configurations to tune or tweak to help with specific nozzle/hotend configurations. I wish we had a developers manual as well as an operating manual, but with Cura advancing so quickly, that's tough! Spend some time in some profiles and then see if you can ask some of your deeper questions here or at Freenode on IRC #cura or #cura-dev channels.
