help
Cunibon
hey i have a problem. my pc just had a went out while i was doing something in cura. then when i tried to start it again it said fatal error and deletet all my settings and everything. which would not be a problem if i could use my old profiles but even though i used the exact same settings and machine as last time there is only a window popping up that says its not the same machine. is there some way arround this to get my settings back
pls help
