Z Offset with BLTouch?
3DStyle
Posted (edited) · Z Offset with BLTouch?
Hi there,
A quick question.
If I'm using a BLTouch to level my bed, and lets say for some reason the BLTouch is not calibrated right, hence the first print layers are getting squished.
If I set a Z Offset from the Cura ''Build Plate Adhesion'' setting menu, will the printer listen to it, or the BLTouch will override it?
Edited by 3DStyle
