Posted · 13.06.4 Project Planner Failures
I had a lot of fun with 13.06.x during the last, past days.
Until now. Until printer number three sunk its head directly into an object :-/
It looks like the new project planner ignores or misinterprets the given head sizes in the preference menu.
Play with it and watch the grey zones around the models!
Additionally, the lack of specifying the order of prints makes things even worse
because the algorithm seems to work only towards a positive y direction.
If the head size towards y-max is only 10mm, but has 80mm to y-min,
one loses 70mm of space because there's no way of telling Cura it better
starts with the object at y-max.
And because Cura 13.06.4 does not care about the y-min size, I lost an extraordinary beautiful fan shroud in a plastics vs. plastics fight :(
    Odd, there is code in place to account for this "switched around fan" setup. Because, my home printer has this.
    I'll do some tests to be sure. See Cura/util/objectScene.py, it has "leftToRight" and "topToBottom" variables that it uses to see if it needs to go in one direction or the other depending on the head size.
    I do think 10mm is too little, a normal Ultimaker has ~18mm between the nozzle tip and the end of the head in the shortest direction.
    • 4 weeks later...
    I didn't use the project planner for a while, an unforgivable mistake:
    Whamm, there went another fan...
    Short description:
    Although the "scene" sort- and placing algorithm takes care about object hits, it completely
    ignores their order. At least, not in relation to the size of the printing head.
    I didn't test this on my Ultimaker and concentrated on the y-axis, because the crashed machine has
    the fan towards y-min.
    Maybe that's the reason because it's working for most of us while we're using the Ultimaker?
    With the fan on the left side?
    My (debug) settings:
    xmin 100 ; only to block x-placement
    xmax 100 ; only to block x-placement
    ymin 50
    ymax 1
    Try swapping ymin and ymax and look at the gcode output (or put in some debug prints
    after sorting completes or the slicer starts to work):
    The objects are always sorted in the same (wrong) direction...
    Here are my findings, so far.
    def setHeadSize(self, xMin, xMax, yMin, yMax, gantryHeight):
    self._leftToRight = xMin < xMax
    self._frontToBack = yMin < yMax
    self._headOffsets[0] = min(xMin, xMax)
    self._headOffsets[1] = min(yMin, yMax)
    self._gantryHeight = gantryHeight
    Ok, a clever solution (except for the overall readability of the algorithm, which got lost without a single comment :wink:
    Indeed, if we know the right direction, towards the longer head part, we only need to
    store the shorter dimension.
    Unfortunately, the "scene sorter"
    while len(self._todo) > 0:
    n += 1
    current = self._todo.pop()
    for addIdx in current.todo:
    if not self._checkHitFor(addIdx, current.order) and not self._checkBlocks(addIdx, current.todo):
    todoList = current.todo[:]
    todoList.remove(addIdx)
    order = current.order[:] + [addIdx]
    if len(todoList) == 0:
    self._todo = None
    self.order = order
    return
    self._todo.append(_objectOrder(order, todoList))
    self.order = None
    only cares about the initially created hit map, created via:
    def _checkHit(self, addIdx, idx):
    addPos = self._scene._objectList[addIdx].getPosition()
    addSize = self._scene._objectList[addIdx].getSize()
    pos = self._scene._objectList[idx].getPosition()
    size = self._scene._objectList[idx].getSize()
    if self._leftToRight:
    if addPos[0] - addSize[0] / 2 - self._offset[0] <= pos[0] + size[0] / 2:
    return False
    else:
    if addPos[0] + addSize[0] / 2 + self._offset[0] <= pos[0] - size[0] / 2:
    return False
    if self._frontToBack:
    if addPos[1] - addSize[1] / 2 - self._offset[1] >= pos[1] + size[1] / 2:
    return False
    else:
    if addPos[1] + addSize[1] / 2 + self._offset[1] >= pos[1] - size[1] / 2:
    return False
    return True
    but never about the preferred direction towards the small head dimension.
    Until know, I indeed did not manage to find any code that cares about the direction or am I missing something?
    I was afraid of touching this hell of a sorter code, so I disabled it and wrote a quick workaround that allows
    me to select the order of the objects by simply clicking at them, but that's probably not what you want :wink:)
    It really would be nice having this piece of code back and working!
