Thanks for the quick response!
Will I just feed it through using move material, since I don't see a print core option on the Ultimaker 2+
You don't particularly need a print core to use this cleaning filament. This cleaning filament is delivered as a 'stick' rather than a reel of filament. By parking your print head in the corner of your Ultimaker and perform these instructions you should be able to clean your nozzle.
SandervG 1,519
Yes, feel free to use it in your Ultimaker 2+!
Edit: This does not go for every filament by the way. Sometimes there is a good reason why a material does work on one machine, and less (or not) on another. So good thing for asking
