Posted (edited) · 25mm Hot-End Cooling Fan replacement options?
Is there a favorite nicer third party replacement "Hot-End Cooling Fan" or should I just get the original equipment ones? I'm looking for maybe longer lasting and maybe quieter if the replacement's air flow & static pressure are still decent. I'm willing to spend more if there's something better. I do suspect just replacing the aging fan with a new identical original equipment part will do a lot to make it quieter. The one on the machine probably has 2000+ hours on it.
Edited by JRDM
