Cura to run my Robo 3DR1+
Mudbeast2
Posted · Cura to run my Robo 3DR1+
Hello,
I am new to the group and am trying to use cura as my slicing software. The matter control that came with it crashes with complex designs. It seems I need the start and end Gcode. I enclosed a pic of whats here now. The bed doesn't level or anything, it just starts printing.
Thanks for the help.
Lou
    • 2 years later...
    In MatterControl, you can get the custom G-Code that it starts and ends with from Settings>Printer>Custom G-Code.
    I made a combination of the Cura settings and the MatterControl settings for something I liked more.
    My start G-Code that I use in Cura is:
    G92 E0 ; reset expected extruder position
    M565 Z+1 ; set z offset
    G28 X0 Y0 Z0 ; home all axes
    G1 Z5 F5000 ; lift nozzle
    G28 X0 Y0 Z0 ; Home Z again in case there was filament on nozzle
    G29 ; probe the bed
    My end G-code:
    M104 S0 ;extruder heater off
    M140 S0 ;heated bed heater off (if you have it)
    G91 ;relative positioning
    G1 E-1 F300 ;retract the filament a bit before lifting the nozzle, to release some of the pressure
    G1 Z+0.5 E-5 X-20 Y-20 F{speed_travel} ;move Z up a bit and retract filament even more
    G28 X0 Y0 ;move X/Y to min endstops, so the head is out of the way
    M84 ;steppers off
    G90 ;absolute positioning
    Hope this helps people in the future!
