Posted · Alternating support layers and angles
I'm trying to dial in support settings in Cura and wanted to ask if either of these features exists ? In S3D I'm able to determine multiple custom support infill angles, which are then printed in sequential layers. Results in a more customize able support pattern and supports that are much easier to remove. Is it possible to do the same thing in Cura ? Can't seem to find settings under the advanced support menu that would ? Attached screenshot shows the settings in question and preview result in S3D.  Thanks !
