I added a (manual, fixed) G1 X<where I put the prime tower> Y<Where I put the prime tower> to the "tool end script" in printer settings.
This works, but has the problem that when there is no heat up time needed you run over to the tower needlessly. This is basically ok, I guess. It has helped a ton with blobbing and failed parts.
AbeFM 35
Could we add a tool change script that moves to that position, manually, at the beginning of each tool change? Would that happen before the temperature set?
