Posted · [3.3.1] Can't set brim size
Windows 7 64bit
Ultimaker 3
I'm trying to make the brim smaller. It's by default set to 7mm and I just want it to be around 5 lines. But as soon I change any of the brim parameters:
Brim Width (7mm) = 5mm or
Brim Line Count (17) = 5
It calculates and resets them back to 7 resp. 17.
I have also tried to set Skirt/Brim Minimum Length to 0 (disable) it, but still, the other parameters always reset back.
I just want Brime Line Count to be 5.
    • 1 year later...
    • 8 months later...
    I figured out how to be able to change this again.
    There is probably another way but, I just switched to skirt and then sliced the model. Then I switched back to brim and all of the settings were available and they actually created the brim width that I set for it.
