How to choose the Raft Base Extruder.
Posted · How to choose the Raft Base Extruder.
Hello.
I am using version 3.3.1 of Cura.
My printer is using two extruders.
I want to use Extruder0 on the first layer of the Raft Base and Extruder1 on the second layer.
My build plate does not have supporter material attached.
Thank you for your help.
    You should be able to select the brim/raft extruder. If you don't see the setting it may be hidden you can add settings by clicking on the gear (advanced settings)
