mechamecha 64
There is definitely a visible difference between 0.05 mm layers vs. 0.25 mm, and banding is quite evident when very thin layers are unnecessarily added to fairly straight vertical surfaces. Also, I'd prefer not to waste valuable printing time adding very thin layers to details that are less important to me on a model. I'd be very surprised if I were the only person wishing that the adaptive layers feature had slightly more versatility.
For example, if I were much more concerned about eliminating the visible banding on the exterior of this very simple object than having the arched opening printed as nicely as possible, it certainly would be nice to tell Cura to ignore the arched opening when calculating adaptive layers. It would reduce the print time as well. Obviously the problem is exacerbated on more complex models.
Edited by mechamechaComments added to posted screen capture
Ricky 5
How can your human eyes can identify which layers are identical or not. You are making bad assumption.
In addition, if there is 100 layers in the slicing, do you really want to add your human heuristic?
