Help split large models into smaller pieces
A1phaOm3ga
Posted (edited) · Help split large models into smaller pieces
I took a look at it. But it is not an easy split because there is no even slice ready to go. Also, you kinda left off particulars on how big your print area is and such. This would be a major factor as well.
Edit: You should look at meshmixer to do this. It is free and learning it will keep you from running into these things. ?
Edited by kmanstudios
    Posted · Help split large models into smaller pieces
    57 minutes ago, A1phaOm3ga said:
    Hey, I been playing around with it too.. my build volume is 240 x 240 x 300 I have two anycubic kossel.
    I suggest this as the way to go as it will give you the most direct results you like.
        How to Enter
        Design an Ornament
          Entering a new design
        Entering an existing design
        Winning designs should:
        Be original Creations
        Good luck 🎉
        • 1 reply
        • 14 replies
