Posted (edited) · UM3 not starting
Hi
Can anyone help please,
My UM3 will not get past the start up screen when I turn it on, I have tried waiting turning it of with USB in and out unplugging the power from back.. The last thing I did was try and print ASA an ABS setting with higher temp settings on build plate with adhesion sheet stuck on glass, it times out saying it took to long to heat build plate. After re starting all I get is Ultimaker on the display. The fans briefly start up but cut out quickly (I forget if its normal or not)
Thanks
John.
Edited by JohnG
