Auto level sequence is backwards
acawthon
Posted · Auto level sequence is backwards
I’ve had a half a dozen table adjustments so far and each time it performs this it goes to the right, flips the #2 nozzle down and checks the height of #1 nozzle and then vice versa. The comment it makes is that the difference between the two nozzles is not within spec.
It prints fine if I just ignore the warning. I’m concerned this may lead to something more serious. What should I do?
    What printer is this?  Um3?  S5?
    It's important that the nozzles on the cores have no plastic on the tip as that gives a leveling error.
    Personally, on my UM3, I haven't done autoleveling in over a year.  I prefer the manual leveling.  You don't have a choice however on the S5 (current firmware version anyway).
    It’s a UM3. I have a UM2+ and rarely level the bed. Guess I’ll be manually setting both when I need to. It once worked properly. Maybe the next firmware update will fix this.
    Thanks for the feedback gr5
