Max Buid Volume & Brim
greens83
Posted · Max Buid Volume & Brim
Ok I have a problem with Brim. I have an upside down cone shape to print, the top of the cone is just within the max build volume, the bottom is only 20mm diameter or something. My problem is I cant use the brim setting without having to shrink the model, which I dont want to do. Im assuming the brim setting adds the brim width to you models max dimensions. It should really add to the first layer max dimensions to avoid restricting build volume on models larger at the top than bottom. Is there anyway around this that anyone knows of?
Thanks in advance for any input.
