I narrowed it down to if I increase the Z size by 1370 percent which gives 12 layers (0.2mm layer height and 2.4 mm total height) the scalable prime plugin adjusts E for all layers (as expected). If it is under 12 layer height then the plugin doesn't adjust any of the layers.
I wonder what is triggering it to start working. I use 0.8mm top and bottom thickness. 0.8mm wall thickness Top layers ends up being 4 as well as bottom layers. I use a 0.2mm layer height but set the bottom layer to be 0.3mm.
Adam324 13
I have included my profile.
Download the test pattern here...
https://www.thingiverse.com/thing:2479352
Scale only Z height by 1250% and then generate the gcode and look at it. You will see that the scalable extra prime plugin didn't adjust E.
Scale only Z height by 1370% and then generate the gcode and look at it. You will see that the scalable extra prime plugin adjusts E properly.
AdamProfile-withscalableextraprime.curaprofile
280x280_mm_Bed_Level_Calibration_scalableprime_extraall_12layers.gcode
280x280_mm_Bed_Level_Calibration_scalableprime_extraall_11layers.gcode
