code is here , it always the same development going on
I have too much going on to go hunt for your code in other topics, sorry.
Please have a look at cura.log in your configuration folder. It will tell you if there's a (Pyhton-)error in your code. The file is probably fairly large. You can delete it and Cura will create a new one. Then start Cura and the log will tell you what is going wrong.
Specifically the bit " -> List[PrinterOutputDevice] " is called "type hinting"; it tells Python what sort of data to expect. It is optional (but recommended). It could be that Python is having an issue understanding what "PrinterOutputDevice" is; are you importing it?
from cura.PrinterOutputDevice import PrinterOutputDevice
yes of course is standard in pluging import statements i have
the log says that :
2018-08-02 12:44:57,266 - ERROR - [MainThread] UM.Qt.Bindings.PluginsModel._update [61]: BedlevelPlugin is missing a plugin metadata entry
2018-08-02 12:44:57,347 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [301]: file:///C:/Program Files/Ultimaker Cura 3.4/resources/qml/Topbar.qml:19: TypeError: Cannot read property 'stageId' of null
2018-08-02 12:44:57,348 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [301]: file:///C:/Program Files/Ultimaker Cura 3.4/resources/qml/Topbar.qml:104: TypeError: Cannot read property 'stageId' of null
2018-08-02 12:44:57,349 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [301]: file:///C:/Program Files/Ultimaker Cura 3.4/resources/qml/Topbar.qml:175: TypeError: Cannot read property 'stageId' of null
2018-08-02 12:44:57,350 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [301]: file:///C:/Program Files/Ultimaker Cura 3.4/resources/qml/Cura.qml:433: TypeError: Cannot read property 'mainComponent' of null
2018-08-02 12:44:57,352 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [301]: file:///C:/Program Files/Ultimaker Cura 3.4/resources/qml/Cura.qml:427: TypeError: Cannot read property 'mainComponent' of null
2018-08-02 12:44:57,353 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [301]: file:///C:/Program Files/Ultimaker Cura 3.4/resources/qml/Cura.qml:465: TypeError: Cannot read property 'sidebarComponent' of null
2018-08-02 12:44:57,354 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [301]: file:///C:/Program Files/Ultimaker Cura 3.4/resources/qml/Cura.qml:497: TypeError: Cannot read property 'sidebarComponent' of null
this error disappear if i eliminate -> List[PrinterOutputDevice]:
last versione works and works fine also in 3.4. thanks for hints
ahoeben 1,968
Without the rest of the code or an understanding of what your plugin does, there is no way we can tell you if that code is required.
