I will do if I can find where the logs are saved. I have done a search of the computer and cannot find any.
I have found the cura log file, but it doesn't mean much to me, maybe someone else can work it out?
Hmm, I don't see anything odd either. What is the exact message that it gives you?
This is really weird. As far as the logs tell me, it never even got to the bit where the legacy reader did anything.
Alternatively, you could export the profile again from the version where it did work.
I went to the Windows 8.1 machine and exported the profile. I then imported the profile using Cura 3.5 on the Windows 10 machine with no problems. Very strange. Not very good if someone doesn't have another operating system to transfer the profiles from. There must be a reason for this, maybe just an isolated problem on my machine which is brand new (HP Elitebook)
Not so easy as I first thought. The imported profile doesn't have all the important parts of the original start and end code.
Not able to use 3.5 the same way as before when using 15.04.06
Also some important items are missing from the new version, like breaking an STL file into objects being the main one.
I often designed parts together so that the various parts would fit together, then using 15.04.06 I would separate them for printing.
Not able to do that now.
nallath 1,125
Could you also share the logs that cura gives?
