I'm also having this issue with Cura 3.5.0 and 3.5.1. This happens with walls with width of 1.2mm and 2.0mm. I made a series of cubes, ranging from 0.8mm to 2.3mm and sliced them with 3.4.1 and 3.5.1. These are the results:
I saw that, if I change the Top/Bottom Pattern to something different from Zig Zag, 3.5.1 behaves like 3.4.1.
I'm attaching my stl test file to help you to reproduce the issue.
Best Regards!
burtoogle 515
That wall is being printed as an outer wall and a skin. There's no inner wall in either case (it would be green not yellow). So Cura must think that the gap is too narrow to fit a wall into. Try reducing the line width slightly and it may then fit the inner wall in and with overlap compensation enabled and the min wall flow hack enabled, it should print as a single inner wall (green) surrounded by an outer wall (red).
