Cura printing issue - different printing style ?
akar
Posted · Cura printing issue - different printing style ?
Hi, after some time I started to print again on my Anet A6 printer, so I have installed the newest Cura 3.5.
Unfortunately, the printing quality is bad. The printer does not put the line on the new line, but it is trying to do some 30 degrees connections.
See the picture below where on the left side is the bad printout and on the right side is the correct one.
I tried different settings. Unfortunately, I haven't found the way how to fix the printing quality - to have the printout nice and smooth.
Thank you for help
Regards
    • 1 month later...
    I think a material with a 2.85 mm diameter got selected during an upgrade. Does the materials dropdown Show Ultimaker materials?
    Could you try reselecting generic PLA?
