Missing profiles
UAVforfun
Posted · Missing profiles
Problem Solved.
It was a network connected printer UM3E. Custom as in you can either select Recommended or Custom. Settings are irrelevant.  There was only 1 choice (.2mm-Fast) to select at the top when you open up the profile drop down.  In any event I fixed the problem. I removed my UM3E in the Manage Printers window and reloaded the printer and re-connected.  All of the various choices came back, ie., Fine, Normal, and Fast. Thank You for responding hutch.
        • 21 replies
