Porte-sonde_Anet_A8_droit_18mm.stl
CURA 3.5.1 impossible to record the Gcode file
what ever the STL file I am facing always the same issue (CURA 3.5.0 or 3.5.1)
Hi @r083726, thanks for the files. Unfortunately, you provided everything except what I need to see which is the project file. Please do File -> Save rather than File -> Export and attach the resulting .3mf file. Thanks.
Sorry to be a pain but I need the project file. That file (cura3-5-1.3mf) is not a project file, it only contains the model and not the models + settings. Please do File -> Save and attach the saved project file. Thanks.
No problem, here is thr project recorded according to your advise
Thanks for the project file. It fails to slice because the Print Sequence setting is set to One At A Time and that appears to trigger a bug. Setting that to All At Once allows the slice to go ahead. I will open a bug report for the failure. Hope this helps.
thank for your reply, I will try tomorrow
burtoogle 510
Hello @r083726, please save the project and attach to this thread. Thanks.
