But with ChangeAtZ you have to set it manually and you can not save it as preset ?
You've a hint about the other options?
gtx
gtx
Yes you have to do in manually and also remove the post processing script after your print, otherwise it will be applied to all future prints as well.
It is not what you are looking for, but a workaround.
Is there any updates on this?
Smithy 1,141
Hi
You can try the Post Processing Script "ChangeAtZ" to change the Extruder Temp at a specific height. But there are also a lot of other options there, so maybe you find something useful.
Greetings from Vienna too ?
