Posted (edited) · How to edit head default gcode by cura ?
in start point on gcode file
i need make default move x y z
to point
G28
G1 Z50 X150 Y150 F1500 ; move finished print out front
like
;FLAVOR:Marlin
;TIME:13434
;Filament used: 11.3018m
;Layer height: 0.15
;Generated with Cura_SteamEngine 3.5.1
G28
M140 S80
M105
M190 S80
M104 S245
M105
M109 S245
M82 ;absolute extrusion mode
how to edit file default code ?
thankyou
Edited by Witawat
    Posted · How to edit head default gcode by cura ?
    Cura only adds that heating sequence before the start gcode if it sees that you don’t have heating commands in the start gcode snippet. If you put M109 S{material_print_temperature} in your start gcode snippet, Cura will not have to add extruder heating by itself. Same with M190 S{material_bed_temperature} fir the bed.
    You could also use a postprocessing script to modify the gcode.
