yes you are right. There are red areas in the x-ray view. But I have no idea how to prevent those areas in the string!? I have used FreeCAD to generate the stl-file. And in FreeCAD I can't see any problem. But at least it seems it is no Cura related topic any more. Nevertheless Thanks.
nallath 1,125
Did you look at the model in x-ray view? It could be that the model is broken. If there are red areas in the x-ray view, than thats probably the case.
