Auto inserted M104 T0 S0 during print with dual extrusion.
guanu
Posted (edited) · Auto inserted M104 T0 S0 during print with dual extrusion.
I use 2 extruders with 1 hotend, and everything works great, except Cura keeps putting in a M104 T0 S0 at the end of tool 0's model.
If I have a model that is 2 colors, and tool 0 ends and tool 1 continues the rest of the print without going back to tool 0, Cura will insert a M104 T0 S0 at the last layer of tool 0's model.  This is a problem when running with a single hotend and will turn off the temp for the hotend for the rest of the print and ruin the print.  Is there any way to prevent cura from inserting this command in the gcode and let me control shutting off the heat with the end gcode?  This seems to be a serious problem for single hotend with dual extruder machines depending on the model.
*quick edit:  I have both printing temps and standby temps set to full temp on both extruders in the slice settings.
Edited by guanu
    • 3 weeks later...
    Posted · Auto inserted M104 T0 S0 during print with dual extrusion.
    I'm running into the same problem with my Geeetech A10M + Cura.
    I have attached a sample file exhibiting the problem. I have yellow color mounted on the second extruder, so I sliced this yellow model to be printed using the second extruder. However, the nozzle turns off after printing the skirt.
    I will look into the source code next to find out where the erroneous M104 is emitted.
    In the meantime, a workaround is to run a postprocessing script that replaces "m104 t0 s0", "m104 t1 s0", and so on, with an empty string.
    CFFFP_fuesse_schnabel.gcode
    Yeah, that is the current workaround one of our distributors is doing.  Having to load the gcode and do a search and remove the line is a workaround, just kind of a pain when that line should not be put in there in the first place.  I have not had the time or knowledge to fix it in the software and wanted to bring it to attention since it needs to be addressed for people using a single hotend with multiple extruders.  Hopefully it gets noticed.
    • 2 weeks later...
    I have the same problem with my Geeetech A10M (one nozzle two extruders). It's very frustrating, I cannot print a bicolor model with Cura.
    My printer works in bicolor models in Repetier-Host using Cura profile where the gcode is situated in one place for both the printer and the extruders. The dual extruder is configurable (one nozzle for 2 extruders), while in Cura this configuration doesn't exist....
    What does you extruder starting code look like? What version of Cura are you running? I have a Creality CR-X and do not have a M104 T0 S0
     until the very last line in the Gcode and I am using Cura 4.0 beta
    Edited by Steverc1572
    I use Cura 3.6.0
    Here is my configuration :
    Printer
    Start G-code
    ; Custom Start G-code
    G28 ; Home all axes
    G92 E0 ; Reset Extruder
    G1 Z2.0 F3000 ; Move Z Axis up little to prevent scratching of Heat Bed
    G1 X0.1 Y20 Z0.3 F5000.0 ; Move to start position
    G1 X0.1 Y200.0 Z0.3 F1500.0 E15 ; Draw the first line
    G1 X0.4 Y200.0 Z0.3 F5000.0 ; Move to side a little
    G1 X0.4 Y20 Z0.3 F1500.0 E30 ; Draw the second line
    ; End of custom start GCode
    End G-code
    ; Custom End G-code
    G4 ; Wait
    M220 S100 ; Reset Speed factor override percentage to default (100%)
    M221 S100 ; Reset Extrude factor override percentage to default (100%)
    G91 ; Set coordinates to relative
    G1 F1800 E-3 ; Retract filament 3 mm to prevent oozing
    G1 F3000 Z20 ; Move Z Axis up 20 mm to allow filament ooze freely
    G90 ; Set coordinates to absolute
    G1 X0 Y{machine_depth} F1000 ; Move Heat Bed to the front for easy print removal
    M84 ; Disable stepper motors
    ; End of custom end GCode
    Etruder 1
    Extruder Start G-code
    G1 X{prime_tower_position_x} Y{prime_tower_position_y} F20000
    T0 P0
    G92 E0
    G1 E3 F5000
    G92 E0
    M18 E1
    Etruder 1
    Extruder End G-code
    G92 E0
    G1 E-3 F5000
    G92 E0
    Etruder 2
    T0 P0
    G92 E0
    G1 E3 F5000
    G92 E0
    M18 E1
    Etruder 2
    Extruder End G-code
    G92 E0
    G1 E-3 F5000
    G92 E0
    With the 1rst extruder all is correct, the prints are perfect.
    But when I want to print with 2 colors, after printing the 1rst color the nozzle stay in place for several seconds, doesn't move to the prime tower and, before beginning the 2nd color of the model, the temperature fall (in the LCD screen to 175°) so the extrusion isn't hot enough for the 2nd color.
    I've tried to put some M104 instructions in some places but with no result...
    Thanks for your help !
    Try adding to your extruder start code
    M104 S{material_print_temperature} after your G92 E0 on both extruders. That is where I used it on my Creality CR-X. But as for the 1st extruder swap.  where it never goes to the prime tower,  I posted that problem earlier, the only way I know to cure that is to make sure you have skirt big enough to handle the color purge.
    Thank you I'll try that.
    A skirt is only for the first layer so the problem isn't solved for the purge betwen colors in higher layers...
    I'll tell you later if your solution works for the gcode for the A10M.
    No result, still the same as before.
    I'm thinking to try reinstalling json files or look at Marlin firmware.
    For the moment I'll take a break and print only with one color at a time.
    I'll come back if I find a solution.
    At last, I've found the solution : there are two versions of Cura json files for the A10M. One of them doesn't works for me.
    The good one is on Geeetech forum:
    http://www.geeetech.com/forum/viewtopic.php?p=89761&sid=c51926817bf3f514d4c61542c44767f7
    There are some changes to make in Cura Machine Settings : size of the printer setting is wrong, change the width, depth and height (X 235 Y 235 Z 260. And in Left and Right extruders tab: Size nozzle 0.4 and material 1.75 mm.
    In Cura all the G-code is in the Printer tab. Extruders tabs are empty. And it works fine even for the prime tower. I think I'll need to configure its size for a better purge but it is already a big improvement.
    In Start G-code, I've added G-code for drawing two straight lines before beginning printing and in End G-code to bring the bed at the front for easy removal of the print.
    Here is my Start G-code
    G28 ;Home
    G29 ;For ABL
    G1 Z15.0 F6000 ;Move the platform down 15mm
    ;Prime the extruder
    G92 E0
    G1 X7 Y25 Z.3 F5000
    G1 X7 Y180 Z0.3 F1500 E0
    G1 X11 Y180 Z0.3 F5000
    G1 X11 Y25 Z0.3 F1500 E0
    G92 E0
    End G-code
    M104 S0;Cooling the heat end
    M140 S0;Cooling the heat bed
    G92 E1
    G1 E-1 F300
    G28 X0 Y0;Home X axis and Y axis
    G1 Y220 F6000
    M84
    Left Extruder and Right Extruder tabs are empty
    Hope it will help some users. If someone want the explanation in French, let me know.
