Maximum Layer Time
mtnbkrrick
Posted · Maximum Layer Time
Hello,
I am looking for a feature that would allow me to set a maximum layer time in seconds to ensure that the layer doesn't cool to fast.  This would allow me to predict a minimum layer to layer strength.  Is there something like that in Cura now that would do this? Or other recommendations?
Thanks!
    There is the opposite, there is a minimum layer time, which helps if you print small objects to give the layer enough time to cool down.
    To specify the maximum layer time makes no sense to me.
    Yep, I’m familiar with the minimum layer time. That doesn’t help if you want to have strong parts and to print fast on a large format printer.  The recoat times of layer to layer make a huge difference in strength of the part.  Ie: I make a large part and it takes 1 minute to start printing in that same spot again vs having a maximum layer time of 30 seconds, then the printer would speed up to make 30 seconds. This is really important if you are printing with semi-crystalline materials.  I tensile test these results at work at different layer times and the results change a lot. The part may look the same if you are just trying to make a pretty part, but they are totally different for structure. Does that make more sense?
    Thanks
