Found a answer:
Yes, Cura turns off the heating for an extruder that will no longer be used for the remainder of the print (something like M104 T1 S0
). If there is only one extruder and one heater, then the printer just ignores the T1
and sees M104 S0
and this then turns off the heating currently printing nozzle, causing the print to fail.
Rene6 0
So, I tried again, manually removing "M104 T1 S0" from my g-code. Now it prints fine. So:
Good: I know whats wrong
Bad: Why is Cura adding this line mid-print?
Summary:
- I load a file with support and print everything with extruder 1. No issues.
- Same file but I select the support to be printed with extruder 2 -> Cura adds "M104 T1 S0" to the g-code. Mid print the nozzel temperature goes to zero and the extruders blocks. Printer keeps going.
Anybody? As I print dual feed nozzel I have all temperatures set to 200. Incl the standby once. And I use Cura 3.6.0
