I need to print small prototype seals they would be like a flat edged O Ring. Size 9mm diameter outside and 7.75mm diameter inside and 1mm thick; sort of a flat gasket. I need some stretch but only about 10 or 15%. Will this work and work on my UM3 .25mm core?
I used you link to DSM but it led nowhere with the company..I did get a email reference but I need to know this now...pressed for time.
Thanks, JP
Whiteknuckle 1
Howdy,
Thanks, JP
