Temperature Issue for multiple extruders
JohnKray
Posted · Temperature Issue for multiple extruders
I'm having an issue with the start gcode for the custom printer definition I'm working on. I need the printer to heat the hotend to the temperature for material 1. However, if multiple materials are being used with different printing temperatures, the highest temperature is set to T0 regardless if that material is assigned to T0. I have copied my start gcode below and bolded the two lines that are causing problems.
M98 P/sys/messageprintstart.g
M104 S{material_print_temperature_layer_0} T0 ; set extruder temp
M140 S{material_bed_temperature_layer_0} ; set bed temp
G32 ; home xy
M190 S{material_bed_temperature_layer_0} ; wait for bed temp
M109 S{material_print_temperature_layer_0} T0; wait for extruder temp
M98 P/sys/homeu.g
G1 X-12.5 Y0 F6000 ; Position Tool Head for filament change
M83
G1 U0 F2000 ; Position filament selector for bay 1
M83
M116
