Thanks for the reply - I'm in CT.
I found some 70D on Amazon, let's hope it's not a typo hahaha.
Regards
Regards
Ok, so you're in the U.S. - meaning it probably won't help you if I give you a link to some european shop's offer ;)
Glad that you found something - be aware though that Shore 70D will be really, really hard, not just a little bit harder than Shore 95A. With 70D, you are well into the "territory" of normal thermoplastics, for example PP will, according to the sources I found online, have between 70 and 80 Shore D. With TPU, you will still get the elastomeric spring-back properties PP doesn't have, but a Shore 70D TPU won't be very flexible anymore probably.
P3D 46
Hi, where are you located? There are lots of TPU 98A filaments out there, and some even harder TPU 58-60D ones. Shore 100A isn't reliably measureable, since it is defined as zero indentation by the probe - a granite slab would also have "Shore 100A", even if this rating is meaningless. Shore D uses a different probe and a much higher loading. See also http://www.m-coat.com/Shore A-D conversion.pdf .
