Posted · suggestion for improvement
I propose to improve the viewing mode of cutting layers. Each layer is painted in a specific color depending on the value of the parameter that displays the color (speed, layer thickness, line type). There is also a strip with a gradient of colors. But for this band it is impossible to understand the value of the parameter that displays the color. I would like that when you hover the cursor on a color trail on a 3D model, under the cursor, a list of parameters characterizing the current print time will appear. And on the gradient bar should display the area corresponding to the current value of the parameter with a numeric display.
          • Heart
        • 4 replies
