Posted
· Cube with inner structure: not enough outer walls
Hello @McMorton, welcome to the wacky world of 3d printing!
It's very common when 3d printing that when you add some internal feature to a model, it can have an effect on the outside of the printed part. The effect can either be very subtle like a small variation in the outer wall profile or it can be much more obvious like some under/over-extrusion or other bad quality issue. Sometimes you can reduce or even eliminate such effects but choosing to print the outer wall first or the infill first or change the number of walls, infill pattern etc. There's quite a lot of variables to play with which is why we all spend hours tweaking settings to try and achieve the best results for a given model and material. At the end of the day, no matter how expensive the FDM printer, there are limitations to the achievable quality due to the nature of the technology.
burtoogle 508
