Hollow out object
egoaudio
Posted · Hollow out object
Perhaps this has been discussed before but I have not found answer to my specific question. It seems this experimental option is not available anymore. I am trying to minimize material (infil) for a very basic design (cone with flat bottom) and don't want to use use infill on those areas which do not need it (support). How to I add support to the inside of my object without using infill? is there a way currently? Does other slicer software allow this?
