Thanks for the reply Smithy. Yes, i know in the layer pause, but this method is not the best for this scenario. I looking exactly the same way for pause when finish each object, not layer. I know that i need modify code, but like you i don't know wich code i need to write and where.
Edited by Carlos4072
Smithy 1,131
As far as I know, there is no possibility, except manual editing the gcode, to pause the print in the kind you need it. There is a plugin to pause at a specific layer, but you would need it in the same layer.
You can just go through the gcode and add the pause manually where you need it, but I am not the gcode expert and don't know the command or sequence you need for that.
