Posted · One at a time. (Cura 3.6 on Ultimaker Original. )
Hi Guys.
I usually print several small parts and I would prefer to have them come out one at a time. However when i activate this option the exclusion area around each part becomes huge. I can only fit 2 parts. I was able to do at least 9 in previous versions.
I have found several mentions to this issue, that are supposed to be fixed by setting the gantry height to anything over 120mm. I have gone up to 400mm and the issue remains.
Any suggestions?
Print head dimension seem about right.
Using Cura 3.6 on Ultimaker Original.
Thank You
