Raft: Line spacing what is it ?
corngolem
Posted · Raft: Line spacing what is it ?
The tooltip says "..this is the distance between the centerlines of the raft line". What does that mean ?
I'm changing the value but I don't see (in the gcode visualization) any change in the base or interface layer.
P.S. I'm trying to change the spacing between base lines.
    It should change the spacing, but it might be bugged, can always happen. I did not fully test all the raft settings (I'm not a fan of the raft, sorry)
    • 2 weeks later...
    (Back after 2 weeks vacation)
    There is indeed a bug that prevents the line spacing from working. Fix will be out soon.
    If you have better raft settings I would love to know them, so I can make them default for everyone.
