Between the Settings and the Preferences menu. In the same menubar as File, Edit and View.
Where is the Extensions Menu in Cura 4.0.0?
I need to access the post processing plugin but can find the Extensions Menu.
9 hours ago, alfagulf said:Where is the Extensions Menu in Cura 4.0.0?
I’ll just quote myself, from a couple of replies above this:
On 5/13/2019 at 8:57 PM, ahoeben said:Between the Settings and the Preferences menu. In the same menubar as File, Edit and View.
Also note:
On 5/13/2019 at 10:36 AM, ahoeben said:this thread is specifically about the list of plugins listed in the opening post, for the beta of Cura 4.0. Your post would have been more appropriate as its own thread.
- 1
Thanks ahoeben,
Now I found it.
But for some reason under Ubuntu Gnome the menu bar does not look like it is part of the application, may be because of the large Cura logo band just below the menu bar is overwhelming it. See attached image
I spent two day looking for a way to access the Extensions Menu but did not see the menu bar in spite of it is in front of me.
Thanks anyway for your quick response.
Thanks now I got it and can use extensions thanks a ton man
batclaw122 0
Sorry for putting the post here but where it the extensions menu thanks so much for the help though
