Cura crashes when I try to open file
gerb
Posted · Cura crashes when I try to open file
I just downloaded Cura 3.6 on a different computer, and whenever I hit "open file" it freezes for one second then closes the program.  It does the same on other Cura versions except ver15.  I'm on windows 10.
Any suggestions?
    @gerb Check my post here.  Sadly from my knowledge there is no known fix but I went through a couple possible fixes that might help out with your problem. To list the basic ones, Reboot pc, Update graphics drivers, disable anti-virus, check firewall settings and exempt Cura, then possibly uninstalling and deleting all config files and then reinstalling.
    In case anyone else is having this problem, dropping files directly onto the cura program works to open a file and saving directly onto an SD card works.  Now I'm just trying to figure out how to upload a profile...
