Hey, you made the firmware I am running! :D
I have finished the script, and it does what I wanted:
The T-rex looks a bit sad but I should be able to fix it by tuning the retraction setting.
The M600 command is ignored, but the M0 works just fine, just needed to modify the other pausing script a bit.
And it turns out finding the top layer is not so straightforward, I tried using the ";LAYER_COUNT" value-1 but that gives a bigger number sometimes, using "data[-1]" just give me M107 and the things after. I end up going backward in the data and just use the first layer I found.
If anyone want to try it here's the script:
https://github.com/cashlo/Cura-post-processing-scripts/blob/master/PauseAtTopAndBottom.py
Edited by cashlo
1
tinkergnome 917
One thing to consider:
the UM2(+) does not support M600 AFAIK, but you can change the filament during a normal pause (M0).
To mimic the stacked processes of S3D one has to print one model / color after another. I don't know if this is possible (only) with post-processing?
The simple way would be to start each "layer" as a separate print, just take sure that the buildplate stays hot between the prints.
Or perhaps combine the gcode files with some scripting?
