Different materials for the top/bottom skin
cashlo
Posted · Different materials for the top/bottom skin
I am inspired by this video https://www.youtube.com/watch?v=KV2AjyowXX4 to try printing with multiple color on my single extruder U2+,
My idea is to use a different material for the top/bottom skin, by swapping the material before and after printing the skin.
I want to make a post-processing script to add a "M600 - Filament Change" to the gcode.
Now my question is is there a script that already does that? I am aware of the "Filament Change" script but it only does z level now.
Also, is there a option to only change number of walls for top/bottom?
    One thing to consider:
    the UM2(+) does not support M600 AFAIK, but you can change the filament during a normal pause (M0).
    To mimic the stacked processes of S3D one has to print one model / color after another. I don't know if this is possible (only) with post-processing?
    The simple way would be to start each "layer" as a separate print, just take sure that the buildplate stays hot between the prints.
    Or perhaps combine the gcode files with some scripting?
    Posted (edited) · Different materials for the top/bottom skin
    Hey, you made the firmware I am running! :D
    I have finished the script, and it does what I wanted:
    The T-rex looks a bit sad but I should be able to fix it by tuning the retraction setting.
    The M600 command is ignored, but the M0 works just fine, just needed to modify the other pausing script a bit.
    And it turns out finding the top layer is not so straightforward, I tried using the ";LAYER_COUNT" value-1 but that gives a bigger number sometimes, using "data[-1]" just give me M107 and the things after. I end up going backward in the data and just use the first layer I found.
    If anyone want to try it here's the script:
    https://github.com/cashlo/Cura-post-processing-scripts/blob/master/PauseAtTopAndBottom.py
    Edited by cashlo
    • Thanks 1
        This update is for...
        All UltiMaker S series
        New features
