Hi @ultiarjan,
Thanks for your reply. Ok so this is good news that I might need to disassemble the print core!
So I can remove the print cores manually without using the menu simply by pushing the grips together with my fingers? This is also good news. However, I currently cannot do that - they seem to be stuck. I assume this is because of the filament build behind the cores.
I will add a photo shortly. Sadly there's been a casualty in that one of the print core wires to the Olssen block/nozzle has broken (it was completely encased in filament and had been pushed into an abnormal position).Are these replaceable or will this require the purchase of a new print core?
Thanks again for your help!
ultiarjan 1,223
do you have an idea what is blocking the core for removal? there is never a need to remove core's via the menu, even in normal operation I switch core's all the time without using menu operations (same for fillament change).
If there's a buildup of material blocking the core you may try adding some heat with a hot air blower, but be carefull not to overdo it with the heat...
Without a picture it's hard to see the severity of your issue, so I have no idea if there's a need to still disassemble the head for cleaning. Though it's a pita ofc, it's not to difficult to do, and also the spare parts of the head (besides electronics and the metal bottom) are really cheap, so when in doubt I would replace parts....
