Hotend V2 drawings
Posted · Hotend V2 drawings
Hello all!
I am looking for the drawings for the components of the Hotend V2.
Mainly the PEEK insulator, the PTFE insulator and eventually the brass parts.
I recently had to replace the PEEK insulator as it got deformed. (Although I only print PLA at 220°C max) and the Teflon insulator also got deformed.
I want to machine a peek insulator that should be a bit stronger than the molded version.
Any idea of where I can find the drawings of those parts?
Gaël
    Hi David,
    Thanks for the link.
    Regardig the PEEK insulator, it's fine for me.
    If there is no such document for the Teflon insulator, I'll have to take accurate measurements on a fairly soft material....
    It the field of keeping the Utlimaker an open-source design, shouldn't those new hotend's standard components be properly documented anyway?
    Gaël
